Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Smoother Objects with 17
Steve Jepson
I have forgotten how to make objects have smoother curves.
On the left is the object. On the right are the original lines and curves.
What can I do to make the curves smoother when making objects ?
3 REPLIES 3
Steve Jepson
quick fix is to split the circles so they are arcs. Then it will be smooth as shown on the right.
I am looking for a better way than this kind of work-around.
use the RESOL or TOLER command
Steve Jepson
Thanks. That works!
http://download.graphisoft.com/ftp/gdl/manual/16/002.011.html
