Solid Element Operations, Bounding Box
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2018-10-17
02:06 PM
‎2023-05-23
04:09 PM
Rubia Torres
‎2018-10-17
02:06 PM
Like this example; the dishwasher is hollow when door is opened. Is the bounding box outside or inside this hollow hole?
I'm not sure I understand how I can cut a hole is this cabinet to get the dishwasher in there. Right now the cabinet door is covering the open hole in the dishwasher
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-10-18 03:11 AM
‎2018-10-18
03:11 AM
You could just use a slab with the height of your oven and depth of your oven plus a little extra as an operator in a Subtraction . The extra is a projection from the face of your cabinet for QoL. In regards to the size, there are standard fitting sizes which you should be able to get from your desired manufacturer / supplier.
Ling.
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-10-18 03:40 AM
‎2018-10-18
03:40 AM
The SEO won't use the bounding box of the dishwasher object.
It will use the 3D elements that make up the dishwasher.
If it is hollow on the inside then only the dishwasher walls take part in the SEO.
If you have scripted the dishwasher, then there is a trick to add a solid inside that will only be used in SEO - basically an invisible prism inside that will take part in the SEO.
Otherwise you will have to use a separate slab in a hidden layer to cut the hole in the cabinet.
