Some setting don't know how to off
Cally Ang
May i know how i delete or off that green color? It is linked to the door. Maybe i wrong click some icon so make it show out, now i don't know how to off it. Thank You
Cally Ang
Versions 14
Dell Precision T3500 - Intel(R) Xeon(R) CPU W3550 at 3.07Ghz, 6GB ram, Windows 7 (64 bit)
7 REPLIES 7
What version of Archicad are you using and what is the door objects name?
Without knowing this I would be guessing that it is a Model View Option for the library parts that will allow you to turn on/off the access area.
In older versions it may be a parameter in the settings dialog.
Cally Ang
Thank You~~~ I found it in set model view
Sry forget tell u i'm using archicad version 14
Cally Ang
Versions 14
It is best to add your Archicad version and machine specs and operating system to the signature in your profile (the profile link is at the top of the forum page).
This way you will never forget to pass on information that might affect the answer to your question.
Cally Ang
OK OK... Thanks your suggestion
Cally Ang
Versions 14
Beautiful
Thank you for doing that.
Now if everyone else would do this too then those who answer questions will find it much easier to be more accurate in their reply.
In version 14 and above you should also find an option in the door parameters to over-ride this option on an individual basis.
The MVO setting is a global across the board setting (which in most cases is exactly what you want).
