Split Command - Number or Text
OK,
have been spending all day setting up a zone stamp that when the zone name gets too long, it separates over multiple text2 commands.
The reason I am doing this is because a paragraph doesn't translate well into AutoCAD (translates as one line)
All was going rosy until I put a number in the zone name, and it went bang.
Looking at the split command again, I realised it is differentiated between numbers and text. Is there a way it can find a variable as a number or a text.
This is my current split command, which only contains words.
znx = split(room_name, "%s %s %s %s %s %s %s", zn1a,zn2a,zn3a,zn4a,zn5a,zn6a,zn7a)
I hope my day of work hasn't been wasted
3 Replies 3
Frank Beister
You could check the variables by a VARTYPE command and can afterwards return the numbers into chars by STR command.
I would better try it in something like a loop to search by STRSUB for the spaces, check the cumulated width and add it to two new strings - segent by segment.
Frank Beister
width=8 ! paragraph length in m
oneline="The quick black architect jumped over the lazy programmer. Lore ipsum!"
! settings
DIM absatz[]
i=1
absatz=""
factorT=GLOB_SCALE/1000
last=0
space=1
DO
	space = STRSTR(STRSUB(oneline,last+1,255)," ")
	IF space THEN GOSUB "addpart"
	last=last+space
	WHILE space
space=STRLEN(oneline)-last
GOSUB "addpart"
LINE2 0,0,width,0
FOR i=1 TO VARDIM1(absatz)
	TEXT2 0,-0.75*i, "'"+absatz+"'"
	NEXT i
END
"addpart":
IF STW(absatz+STRSUB(oneline,last+1,space))*factorT<width THEN
	absatz=absatz+STRSUB(oneline,last+1,space)
	ELSE
	i=i+1
	absatz=""+STRSUB(oneline,last+1,space)
	ENDIF
RETURN
wow, didn't expect the whole code.
checking A17 translator, it seems to translate better. But still with problems.
Looking forward to trying this today.
Many Thanks!
