Erich
Split Command
Hey folks, I am trying to parse a string output into useable numbers and need a little help.
The string, "dep", is of variable format and can contain numbers such as 7-1/2 or 9 or 10-1/2.
So far I have the following command:
nvars=SPLIT (dep,"%n-%n/%n",nx,ss3,ny,ss4,nz)
IF nz<>0 THEN b=1"*(nx+ny/nz)/2 ELSE b=nx*1"/2
This works great provided that the string for "dep" is represented by a single digit or by the five place format such as 7-1/2. However, when I get to values for "dep" such as 10-1/2 the SPLIT command breaks down for me and will result in a value of 10" not 10 1/2". How can I change this to work right?
I am sick today so this is probably staring me in the face and I just can't see it.
(edit)=============
I found it this morning. It was not that the GDL sytanx was wrong but that I changed the format of my values part way through by forgetting the dash. So the values changed from "XX-X/X" to "XX X/X".
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
0 Replies 0
