ā2004-04-06
08:04 AM
ā2023-05-24
12:50 PM
Rubia Torres
ā2004-04-06 09:00 AM
ā2004-04-06 11:33 AM
Erika wrote:Reading this discussion I may conclude that Graphisoft creates confusion with Libraries and GDL every time new release appears.
I'm confused, are you using 8.0r3 with the 8.1r2 lib or___?
You might try first going to 8.1r1 with the 8.1 lib. See if that works.
ā2004-04-06 05:12 PM
ā2004-04-06 05:55 PM
ā2004-04-06 07:32 PM
Cathy wrote:While I think you are wise to be cautious in adopting AC8.1-R2 (it seems some people have been having problems with it), I have to question the wisdom of continuing to use 8.0-R3. I found all the beta versions of 8.1 to be far more stable and reliable than any version of 8.0 (including V3/R3) and the shipping version (V1) is also more reliable than the betas. Since you are having problems in 8.0, I suggest you try opening the file in 8.1-V1 to see if matters improve.
This is a project without an impending deadline, so I'm using AC81-R2-2256-USA with the AC81-R2-LIB-USA library so I can explore some of the new features.
The projects that actually need to get finished in the next couple of weeks are still in 8.0r3. Fortunately none of those have square bay windows.
