Stair Inner Posts don't show on plan
Brad Elliott
I have inner posts turned on to show in Model View as well as in the stair settings. I also have verified that they are a pen color that shows but am still unable to get them to show up on plan other than as a 1 pixel white line. They do show up when selected. Is there any way to adjust the pen for Inner Posts that will show up on plan?
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
This may be a bug. However, you might look at overriding the Object's Pens under at the Floor Plan Symbol Overrides, at the top level.
Richard
AC26 (since AC6.0), Win10
Brad,
What happens if you select the Railing, enter Edit Mode, then select that Inner Post instance and go to its settings Dialog? Does it have different setting then for 2D representation?
The reason I am asking is because in the Settings.PDF I can see that the Segment page displays a yellow warning sign, which means that components of the Segment have been customized from the default values set in the Settings Dialog.
Brad Elliott
Richard, The override works to show the posts but of course now everything is the same pen weight which I can live with for now.
Laszlo, Good idea but this didn't work. But you are correct, once you start customizing the components the behavior gets erratic.
This stair tool has a lot of potential but it is full of bugs. I hope this doesn't become another ArchiCAD 75% good and then abandoned tool.
M1 Macbook Pro
