Stair without bottom slab
Is possible to achieve with ArchiCAD a stair similar to the attached image?
I am not able to solve it with default stairs...
Thank you!!
undefined
10 REPLIES 10
NandoMogollon
Nope Diana,
I suggest to use a Complex profile and then extrude it with a Wall tool. You may have to change the priority number of your Stair Layer in order to prevent strange behaviours with he profile.
Stair maker is way out of date....
Hope this helps.
Regards
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
Frank Beister
In the German library is a native GDL stair (not Stairmaker) for outdoor stairs. Without handrail, but simiar to this one.
You can use Stair Maker.
Using this settings for Treads and Risers:
undefined
Thank you, but don't understand german 😞
Solved!! Just placed exactly the same value in the three threads, the ones you have marked as green. Looks gorgeous!
Erika Epstein
Or you can use the 4th structure option
undefined
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Thanks Erika. This is even better solution.
Great!! Thank you!! 😄
Regarding the stair, just a quick question.
When viewing the stair in elevation view I can see the lines of all threads.
This makes no sense, would be perfect to see only the contour.
Is possible to achieve that?
Thank you!!
