Standard US aluminum or vinyl windows?
I don't see basic standard US aluminum and/or vinyl windows (similar in profile) for single hung and sliders with the interior finish (drywall) wrapping into the window opening (no casings). I had to take a wood window and modify it as closely as possible to look like it from a distance but won't do for a detail.
Any help would be appreciated.
13 Replies 13
TomWaltz
I the new SE library is a lot better about wall interation than SmartParts.
In our case, it's more that getting 25 people to use a new window object is nearly impossible. First learned first remembered 😞
Tom Waltz
Josephus,
I wonder if CadImage's Door and Window Builder does what you want, with regards to turning wall finishes in. I use it, but not to that degree of detail. Maybe someone else who does can expand on this.
In the attached image it shows skins returning into the opening, interior and exterior faces of the wall. (note that this image was used for another posting, so is not specific for this).
HTH
Thanks for all the different suggestions. I'll look into these asap and see what will be the best way to go for us...got sidetracked for a couple of days with some building department corrections...part of being a 2 man office.
This is my attempt with the AC9 SE library (W Single Hung1 SE) to display as you liked. ( I wish I could say the same for what I want...)
The Jam extension is (live), yet it does not quite clean-up with the Composite wall.
