Steel Joists 12
I am inserting steel joists in my model, the only one that appears to slope is the Bar Joist, I am using steel beam to bear my open web steel joist at 2 different elvations to get my slope, although the bar joist doesn't have the correct parameters to have the top chord extend a different lenght from the left end to the right end. I also have tried using an open web joist object that worked well in AC9, but won't work in AC12. Any suggestions?
1 REPLY 1
