‎2017-12-29 03:33 PM
‎2017-12-29 03:57 PM
‎2017-12-29 05:06 PM
‎2017-12-30 03:25 PM
Karl wrote:Use the Open Object by Subtype... command, then navigate to General GDL Object > Documentation Element > Drawing Symbol > Marker > Story Marker > Built-in Story Marker. It looks like the standard marker is close: set the Text Settings > Alignment to Outside, then if the parameter Marker > Story Name Placeholder could be a negative number (it is currently restricted to => 0), then the text could be inside the marker.
I tried to open the story maker object thinking I might edit it, but I don't see where it is available in the ArchiCAD 21 Library.
‎2018-01-02 02:20 PM
David wrote:Thank you - I'll give it a try.Karl wrote:Use the Open Object by Subtype... command, then navigate to General GDL Object > Documentation Element > Drawing Symbol > Marker > Story Marker > Built-in Story Marker. It looks like the standard marker is close: set the Text Settings > Alignment to Outside, then if the parameter Marker > Story Name Placeholder could be a negative number (it is currently restricted to => 0), then the text could be inside the marker.
David
‎2018-01-02 09:58 PM
‎2018-01-03 03:22 PM
‎2018-01-08 09:00 AM
‎2018-01-09 06:46 AM
