Surface Area of Zone's Bounding Walls
There is here a list of all zone parameters :
https://helpcenter.graphisoft.com/user-guide/76909/
But i am not able to find this parameter into my french archicad :
I hope to find it but where ?
My aim is to be able to get it into an ifc export.
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
1 Solution
Hello Garry,
My first test had been carried out from AC22 and this property is indeed not operational. However since AC23, 24, 25 and 26. Yves was right ! Being used to performing this task with more recent versions, I had never noticed any malfunction on AC22. An old and obsolete problem !
Christophe - FRANCE
Archicad 15 to 29
Go to post
9 Replies 9
poco2013
Mentor
I am using the USA version and I don't see it in the parameters list either. It is available in the schedules parameters and the custom properties list. I would suggest to just create a custom property or expression and map that to IFC.
Gerry
Hello poco2013,
"It is available in the schedules parameters and the custom properties list"
I do not find it into custom properties list. Where do you find it ?
Christophe - FRANCE
Archicad 15 to 29
poco2013
Mentor
In the property manager -- to create a new expression
Gerry
My question was not where can I create a new property but where is the parameter i have illustrated into my first message. It seems to be absent from french version.
Christophe - FRANCE
Archicad 15 to 29
Yves
here
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
Thank you Yves for your participation. I should point out that I had previously tested all possible surface values ​​but none seemed to correspond. The targeted value in Yves' post results in a result of 0.00m2 whatever the zone area.
Is this operational on your side ?
Christophe - FRANCE
Archicad 15 to 29
Yves
On archicad 23 I get the right value
Try updating the zones
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
I am not sure, but has it anything to do with the relation to zones settings in the walls?
Hello Garry,
Christophe - FRANCE
Archicad 15 to 29
