JGoode
Survey Point query
I'm looking into the survey point object. I'm having an issue where if I create my own object and give it the survey point sub-type then export as an IFC it doesn't point north but if I save a copy of Graphisoft's survey point object, it faces north when exporting. Any ideas as to why this happens? Is there something in the code which makes this work?
Thanks
ArchiCAD 27
Windows 10
1 Reply 1
Erwin Edel
If I look at the script they are doing a few 'tricks' to make sure mirrored / rotated objects don't missbehave.
But it mostly just uses GLOB_NORTH_DIR, which grabs the north location from what you've set up in Project Preferences.
Check the 2D and 3D script.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
