TOILET PARTITIONS
Are there bathroom toilet partitions in this package?
Eric Milberger, Architect | Master Planner
13 REPLIES 13
Ahmed_K
Can you explain better with an exemple, or screenshots of what are you want
Archicad 27
Windows 11 professional
Do you mean for commercial bathrooms like the attached object?
One of the forum moderators
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
I guess I just dont get the installation of this product.
It has set up on my machine with only division 8 and nothing else
Not sure where to find the right library without opening too many
Right Now I see loaded in my Library Manager three libraries
Embeded
Open Object
Surface Catalog
Archicad Library 25
Well none showed and then ten minutes later they did
Not as clear as I would like it when something is imported and dont show or show loading
What localization of ARCHICAD do you have? You don't have a signature showing that and your OS, which would help people give you more specific answers.
You're looking at the library with the Object Tool (chair icon) selected?
If you're not USA, which is where this division 10 is... simply use the search box in the Object Settings dialog at the top left (seen in my screenshot) and search for "Bath Stall" and it should show up.
Karl thanks,
For some reason - and I don't gasp as I am trying to spend more time as Architect and not tech.
The libraries don't always show. And sometimes I have to open and keep opening and more show.
I searched for partitions initially and no show.
My setup is a default set up as I dont have the customization required for something special yet.
I tried to use the partitions
It seems that have a way to go
Hou do you offset a toilet?
On a 5' HC stall you have to offset the toilet.
David Maudlin
I use 2 objects for this:
1. Commercial Bath Stall for the partitions, the toilet is off.
2. Toilet ADA for the toilet, which includes the grab bars.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I ended up doing the same - I was just disappointed in not having a full parametric solution
