Eric Milberger
Where is a commercial toilet - NO TANK
I can find no commercial Tankless Toilets.  in 40 years I have never used a tank (residential) toilet in a commercial building.
Cannot find a commercial toilet in Archicad.
Eric Milberger, Architect | Master Planner
9 Replies 9
Eduardo Rolon
It is an option within the toilets:
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Ricardo Lopez
Hi @Eric Milberger
As @Eduardo Rolon mentioned, the default WC object offers many interesting options for creating a pretty decent model of a public toilet; you just need to play around with the settings a bit.
You can also view other available objects by typing "wc" into the search box in the Object Selection Settings, where you'll find even more detailed ones.
Ricardo López, M. Arch.
Eric Milberger
The version 29 I have has no tank toilets
Does that mean you now have the object you want?
Or was that a typo and you still can't find them?
Eduardo Rolon
It has, see above.
AC29 US/INT -> AC08
Eric Milberger
no. NONE MATCH WHAT YOU HAD IN OLDER VERSION OF us TOILETS
Lingwisyer
Guru
Ah. US library shananigans... What fun. What were the US tankless toilets like?
I am not sure what was in the US library in older versions, but it should be the same as what is there now.
There doesn't appear to be a USA plumbing library pack in 29.
These are all of the floor mounted bowls that I see in 29 - with the cistern turned off.
Then there are also wall mounted bowls.
Eduardo Rolon
28 US has the same options as 29
27US too
As does 26 US
AC29 US/INT -> AC08
