Task
PEN 1
HOTSPOT2 A,0
HOTSPOT2 0,B
Agreed_Value =0 ! When object is stretching
Agreed_Value =1 ! When object is installing
IF STR("%m",SYMB_ROTANGLE)=STR("%m",180) THEN ROT2 180
TEXT2 0,0, Agreed_Value
How to do that value Agreed_Value = 1 when object is installing and Agreed_Value =0 when object is stretching?
Thanks.
One of the values you are looking for is supplied by the global parameter GLOB_CONTEXT.
The applicable values are:
22 - feedback mode from the floor plan
23 - feedback mode from a 3Dview
24 - feedback mode from a section/elevation
28 - feedback mode from a layout
These are the returned value while the user is stretching the element in each of the view types.
I am not sure what you mean by "When the object is installing", unless it is simply when it is not being stretched (ie. GLOB_CONTEXT # 22 etc.)
