Texture problem on cprism
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2011-05-02
06:33 PM
‎2023-05-24
11:51 AM
Rubia Torres
‎2011-05-02
06:33 PM
Any ideas would be appreciated.
Thanks
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-05-02 07:44 PM
‎2011-05-02
07:44 PM
Isolate the GDL script element having bad mapping.
Create a new material with the correct direction.
Add a material call for it to the script before the problem element
Add a material call after the element to return to the original material.
Dwight Atkinson
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-05-02 10:16 PM
‎2011-05-02
10:16 PM
Thanks Dwight,
Still no dice. The texture is changing direction on a single surface.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-05-02 10:17 PM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-05-02 10:19 PM
‎2011-05-02
10:19 PM
The material in question is the one with the red arrow. The side surface of the cPrism.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-05-03 07:29 PM
‎2011-05-03
07:29 PM
Could you post the object - would be easier to
rotate and test the texture orientation.
Thanks.
Thanks.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-05-04 09:33 PM
‎2011-05-04
09:33 PM
Hi Juha,
Thanks, I got it sorted out. The piece is a wood veneer over plastic and I just had them side by side. I grouped them together and the problem was solved.
Thanks again
Thanks again
