The Elevator Object
TMA_80
Hi archicaders !
I find the elevator object interesting, the option to make the elevator "read" the story height is great BUT...this option causes problem too, if i want to have a different height for a special level (not the same of the story), the object doesn't allow anything other than the story height, the "edit story" button doesn't even seem to work (the story height still greyed)...
am i missing something ?
thanks in advance
AC12_27 |Win11_64bit|
14 REPLIES 14
Thank you all for replies, seems Erika's solution is working fine.
Achille Pavlidis
F. wrote:
Best would be Elevator would be an opening object, that cuts opening and doors directly into the wall. 😉
amen
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
seasons greeting everyone. i am newbie in archicad. what about creating elevator with north opening at level 1 and south opening at level 2?
David Maudlin
yvan79:
For the Elevator 14 object, you need to edit the parameters, particularly General Settings > Direction of Second Opening, and Door > Name of Story to be Edited and Door Position of Edited Story. It may take a bit of time to get everything correct, but it is possible.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks for the guide....really appreciate it....
