2023-04-19 04:11 PM
The pop-up window allowing to enter distance while drawing a line, a wall or any element is not showing up anymore while drawing.
How can i reactivate it ?
Thank you in advance !
Solved! Go to Solution.
2023-04-20 03:24 AM
Do you have a tool bar button like this?
I am not sure where/if there is a menu item for it.
2023-04-19 08:44 PM
Check your Work Environment.
It should be under Options-> Work Environment -> Tracker and Coordinate Input....
another Moderator
2023-04-20 03:24 AM
2023-04-24 10:03 AM
thank you it worked!
