TESS
The pop-up window allowing to enter distance while drawing a line, a wall...etc is gone
The pop-up window allowing to enter distance while drawing a line, a wall or any element is not showing up anymore while drawing.
How can i reactivate it ?
Thank you in advance !
1 Solution
Do you have a tool bar button like this?
I am not sure where/if there is a menu item for it.
Go to post
3 Replies 3
Eduardo Rolon
Check your Work Environment.
It should be under Options-> Work Environment -> Tracker and Coordinate Input....
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
TESS
thank you it worked!
