Jeff Galbraith
Setting Origin Point of Custom Objects / Library Parts
How do you control the origin point of a custom library part?
I created custom library objects for an acoustical ceiling tile to be used with the curtain wall tool, but Archicad automatically placed the point of origin of the ceiling tiles at their lowest point, so they don't properly engage the support grid.
How can I fix this?
Jeff
Archicad 22
Mac OSX - 10.13.6
Jeff G
Archicad 27 USA (full), Macbook Pro (16-inch 2023, M3 MAX, 128 GB RAM)
3 Replies 3
Lingwisyer
Guru
Are you saving out something made on the floor plan? What is the "lowest point"? As in they are recessed behind the supports? Have you tried including a hotspot when you save it out? Is it modelled at zero elevation? I do not use the curtain wall tool so I am not sure how it interacts with sub-objects...
Ling.
Durval
If you modelled your object using tools such as Wall, Slab, Morph etc, and then saved it as an object, the origin of your object will be at the origin of the 3D space in ArchiCAD.
Before saving as object, drag it so that the intended insertion point of your object is exactly at 0, 0, 0, coordinates.
--- www.dtabach.com.br ---
AC 28/29 BRA – MacBook Pro Apple M2 16GB RAM Mac OS Sequoia
Lingwisyer
Guru
Hm... AC seems to ignore the origin for 2D objects...
