Thick black outline on Elevation Stacker / Sliding doors
Hey guys i have an issue with my walls not showing my sliding and stacker doors correctly. On the image provided the wall on the left is a custom wall i created and the one one the right is a generic wall from ArchiCAD that came with the program. The doors used are exactly the same in the image.
The issue is that my stacker and sliding doors on my wall show a dark outline for some reason but they don't show it on my swing doors. I want to get rid of the dark outline on my sliding/ stacker doors and i think its got something to do with the wall.
Can anybody help please it would be much appreciate.
Thank you
Stef.
3 Replies 3
Erwin Edel
No image attached.
Sometimes a door will use the cut pen of the wall before it is a complex profile or composite. Try changing it back to just a building material wall, adjusting the cut pen to what pen you want your door to be using and then changing the wall back to the composite/complex profile you were using.
This is assuming you couldn't find the proper pen to adjust in the door settings.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Erwin wrote:
No image attached.
Thank you so much that seemed to work!
Erwin Edel
I haven't had it with the 3D pen yet, but this worked for me for a cut-pen for a lintel I think.
www.leloup.nl
