2016-06-07
03:57 PM
2023-05-24
10:47 AM
Rubia Torres
2016-06-07 04:07 PM
2016-06-07 04:19 PM
Erwin wrote:Thank you so much that seemed to work!
No image attached.
Sometimes a door will use the cut pen of the wall before it is a complex profile or composite. Try changing it back to just a building material wall, adjusting the cut pen to what pen you want your door to be using and then changing the wall back to the composite/complex profile you were using.
This is assuming you couldn't find the proper pen to adjust in the door settings.
2016-06-07 04:39 PM
