JGoode
Tick a boolean, turn another off
I have 3 different tick-boxes. When I tick one I want the other 2 to untick and visa versa. However when I tick 1 and then tick another, it doesn't seem to swap due to the first tick-box being coded first in my script. Is there a way around this?
Thanks
ArchiCAD 27
Windows 10
2 Replies 2
Erwin Edel
Are you running this from the Parameter Script?
I think the way it works is, whenever a parameter changes, the parameter script runs, meaning it should check for your IF...THEN statements everytime you tick / untick.
Edit: also unsure of the functionality, but wouldn't it be easier to have one parameter with 3 possible settings?
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
JGoode
I've fixed it now, I just used glob_modpar_name and it's works Thanks for the reply!
ArchiCAD 27
Windows 10
