Tip of the month question
Thomas Holm
I made a custom window following David Pacifio's tip of the month: http://www.graphisoft.com/support/archicad/archiguide/customwindows.html
The window is rectangular, but mullions etc extend in such a way that the default wallhole is created too big. Thus by follwing David's tip, I made the 3D wallhole fit.
But the 2D wallhole (the mask that cuts the wall in the plan view) is still too big (see attachment), and doesn't care about my efforts to make it smaller. Is there a simple way to fix this?
13 REPLIES 13
HI Thomas,
Can you post an elevation view of your window?
Thanks,
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Djordje
... and the window itself?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thomas Holm
Sorry, being in a hurry I'm getting sloppy. (The plan view should have been a .gif). And I had to get some sleep.
Below is a view combo showing dumps (not to scale) from the constructed window's .pln file.
(it looks weird diminshed -please click on it, it's just 16K)
Thomas Holm
And here's a shaded axon view where I placed it too high in the wall, showing that it cuts the wall correctly in 3D.
Thomas Holm
And finally, here's the win object itself. (I'm still on AC7v3).
As you can see, it's a beautiful traditional Swedish window, slightly Baroque in style, although in this case built around 1910. The object is regrettably just a very crude representation of the real thing, which has all kinds of small but exquisite detailing.
In the object's 2D view, i removed the trimmings (no need for them there). And the WALLHOLE command made the 3D cut perfect. But in the plan view, the hole in the wall is still too big (makes room for the trimmings).
The forum refused to accept the WIN file type, so I had to zip it. I used two different types of encoding, see below. Also, i'm not sure if i succeeded to save it in cross-platform format. Please notify if something's wrong!
Thomas
Thomas Holm
Here's the other one.
Djordje
That is the answer to your question. When you make the window that way, the plan hole size equals the width of ALL the elements that make the window - including the trimmings. So the A of the winow is the window hole plus the trimming. Try reducing it in the script.
Djordje
HP Omen
Thomas Holm
Not to be impolite, Djordje, but the question, which it is, can hardly be the answer when I'm asking for a solution!
This way of making a window doesn't generate a 2D script, just a 3D one. Thus I was under the impression that this WALLHOLE command would be used when Archicad cuts the wall in floor plan window too. But not.
And since I can't access this 2D plan wallhole in the object's 2D symbol window or "2D full view" window (why two similar? windows??), and I don't know how to create a 2D script from scratch, I still don't know how to do it. Which was my question in the first place!
I think I still hate GDL.
Thomas
Oleg
Open the script editor. Press the "details..." button.
Type in the X+ and X- fields
-95*A/1410
And save.
Oleg
