Titles referencing sources view ID
Erich
I have searched but did not find this exact issue and am not seeing anything to solve it in the reference manuals.
Is there a variable or request that I can add to a title type so that it can get the view id of a drawing placed on a layout? Obviosly the view name is available but sometime the id is easier to find. This would be useful when reviewing a printed document and needing to change a particular details or worksheet, etc. where there could be a large number of drawings in a folder. I know we can always go to the layout and select the drawing in question to "find" it but I would also like to be able to use the old fashioned way.
Thanks.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
You might try <DRAWINGID> without any requests, for example;
text2 AC_DrawingRect[1], AC_DrawingRect[2], "<DRAWINGID>"
Here are some other automatic texts which might be helpful;
<SUBSETID>
<SUBSETNAME>
<LAYOUTID>
<LAYOUTNAME>
<DRAWINGNAME>
<DRAWINGSCALE>
Best regards, Juha
Erich
Juha,
Good idea, I hadn't tried the autotext options yet. Unfortunately, none of them seem to be able to get the view ID only the Drawing ID in the layout.
I think I may be running into a similar issue to what was going on in this post:
http://archicad-talk.graphisoft.com/viewtopic.php?t=16585&highlight=back+referencing
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
This is not a perfect solution, but it is a decent work-around. you can always have the drawing ID set to be the view ID in the drawing settings
