Learn more
Eric Milberger
Toilets not visible
I have placed toilets and stalls with A25 utilities
The toilets in the stalls show on the plan but not in sections or 3d.
Eric Milberger, Architect | Master Planner
3 Replies 3
DGSketcher
Legend
Check your renovation status for the WC elements and the display settings.
If the WC's are part of the cubicle then maybe they are controlled in the object display settings e.g. an option to "Show in 3D"?
David Maudlin
He is correct. look at Object Settings > Commercial Bath Stall Settings > Fixture Settings... > "Fixture in 3D" check box.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Eric Milberger
I gues I would have preferred a different flow of logic
Right now the way the menus are laid out it is -
pick a toilet or urinal and then display yes or no
Why not
Pick - toilet - urinal or none.
Why would you pick one then display off the fixture?
