2021-10-07 06:42 PM - last edited on 2022-03-10 01:17 PM by Gordana Radonic
I have placed toilets and stalls with A25 utilities
The toilets in the stalls show on the plan but not in sections or 3d.
ALL levels are on.
2021-10-07 11:36 PM
Check your renovation status for the WC elements and the display settings.
If the WC's are part of the cubicle then maybe they are controlled in the object display settings e.g. an option to "Show in 3D"?
2021-10-08 02:51 PM
@DGSketcher wrote:If the WC's are part of the cubicle then maybe they are controlled in the object display settings e.g. an option to "Show in 3D"?
He is correct. look at Object Settings > Commercial Bath Stall Settings > Fixture Settings... > "Fixture in 3D" check box.
2021-12-30 03:49 AM
I gues I would have preferred a different flow of logic
Right now the way the menus are laid out it is -
pick a toilet or urinal and then display yes or no
Why not
Pick - toilet - urinal or none.
Why would you pick one then display off the fixture?
