Erich
Total of array values
Ok, I am feeling brain dead at the moment..
Does anyone have a clean method for getting the sum total of all the values in an array?
For example if you a have a 3 dimension array with values of 2'-0": 1'-4": 2'-3" I need the result of 5'-7"
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
3 Replies 3
Not sure what you mean by "clean", Erich. Do you want something more than just a loop, iterating through the indices and summing things up?
PS I've been brain dead for two days, so can commiserate. 😉
Frank Beister
dim var[3][4]
result=0
for i=1 to vardim1(var)
for j=1 to vardim2(var)
result=result+var
next j
next i
print result
text2 0,0,result
... und im Übrigen bin ich der Meinung, dass Trockenbauwände einschichtig zu modellieren sind.
Erich
Thanks guys. My new son is making sure I can't think straight anymore and I couldn't figure out how to get my loop to work right. Frank hit it right on the nose. I just needed the dummy variable to be the place holder in the loop.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
