Transfer window/door Marker settings?
How can i inject the marker settings of a window or a door to another? there is no setting for marker inside the inject tool.
Also inside a window or doors settings there is an option to load a marker.
can i export a marker from one file and load it to another?
4 Replies 4
Hello papsphilip,
Markers was more used before labels creation.
I prefer to use the labels to the door / window brand since version 21 because the labels are more flexible.
It is probably possible to use marker as well as I use labels but I do not use it because I do not need it anymore.
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
if i understand correctly instead of the built in marker stamps that are available inside the door and window settings you use a manual label ? the one under Document?
Yes
Christophe - FRANCE
Strawbale23
Nice tip
AC26
https://www.zendsign.fr/
