UI_INFIELD Text Type Parameter
Lingwisyer
Guru
Hi all,
Does ui_infield not work with text type parameters?
When I use it with a Text Type parameter nothing happens, while when I use a Real Type parameter it creates a numeric input box as expected.
Ling.
Lingwisyer
Guru
I have found out that it was caused by an interaction with my Master Script. Since I needed the relevant lines in all of the other scripts, I just added a GLOB_SCRIPT_TYPE statement and it is all good now.
Ling.
No problems at all.
Lingwisyer
Guru
I created a new Text Type parameter and it works. Works when I change my Real Number parameters to Text Type too. Need to figure out why it does not work with my existing ones now... They have the same structure as each other...
Ling.
Lingwisyer
Guru
Ling.
