2022-12-22
04:25 PM
- last edited on
2025-07-16
02:13 PM
by
Aruzhan Ilaikova
I want to open objects in STL format in Archicad, but they are always grouped. I'm exporting from Inventor and I don't have any option to ungroup. Does Archicad allow me to ungroup these stl models? Thank you.
2022-12-23 07:04 AM
can you share your STL object from inventor to help you?
2023-01-02 11:08 AM
2023-01-02 08:16 PM
if you convert the file to an object , you can change the textures included in the object , I redomend you export from inventor in a diferent format than STL , because STL do not acept multi textures , its a geometry format only
2023-01-02 08:41 PM
or you can select faces to change texture , give click in the object and select faces with "Ctrl-Shift left Click mouse" , then left click in selected poligon and choose icon "custom face settings"
