Using the Multiply tool in 2D symbol of Library Part
tsturm
Can anyone else verify that the multiply tool in the Library part symbol drawing area does not work at all?
I went to draw an object. Tried to copy some lines evenly distributed across a box. To find that the tool did not work. Even tried to use the pet palette command to do the same thing.
This is the command under the EDIT menu. Right next to move, rotate and such.
We are using 8.1 v1 build 1410 on a Mac under OSX 10.3.2.
TIA
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
6 REPLIES 6
Verified. Can't multiply by keyboard, menu, or palette. AC thinks it works; after trying it the Repeat menu item reads, 'Repeat Multiply'. Bug.
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
Djordje
Must be a Mac thing; works OK on W2K (just checked)
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
tsturm
Went through this with US tech support during a phone conversation.
Seems the problem goes away along with your preference files.
Tech Support had me do a New & Reset. Then we did it again and it worked. Now tell me how often you want to do that.
I am trying the same process in other projects that we have which were not started prior to 8.1 and are not Teamwork versions either. Both were factors in effect when I was working on the library part.
Hope to post another update soon.
Yes, Windows seems to uneffected by this problem.
_______________
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
Aussie John
Is working here
Cheers John
[/size]
__archiben
mac unaffected here also . . .
b e n _ f r o s t
I have no problem with my mac
