Tom Krowka
V10 ROOF SURFACER
Ok, I give up. How does it work? In V9, I would select the roof, go to the roof surfacer in extras, select the options I wanted, close the window, and the surfacer would show up on the roof.
It does not appear to be the same for V10. can't get it to work. What's the secret?
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
2 Replies 2
Link
The secret is to have the Acccessory Library loaded. If you go to Help>ArchiCAD 10 Goodies, you will be taken to http://www.graphisoft.com/support/archicad/downloads/goodies10/USA.html
At the bottom of that page is the Accessories Library. You need to download it and load the extracted library with your project in order to use any of the Accessories.
On the website it says: The Accessories Library is required for using the Accessories and Interior Wizard goodies. After downloading the file uncompress it into the ‘ArchiCAD 10/ ArchiCAD Library 10’ folder.
If you put it in there, it will load automatically with your AC10 Library, but if you uninstall/reinstall AC10, it will probably be deleted! It was so much easier when this was bundled with the AC Library wasn't it?
Link.
Tom Krowka
that'll do it.
Thanks
Thomas@wkarchwk.com
www.walshkrowka.com
