Values of GLOB_CONTEXT
Well, I use GLOB_CONTEXT in my objects successfully. But I only use the value of 1, 2, 3, 4, 5, 6, 7.
I want to know when GLOB_CONTEXT will return 22, 23 and all the others.
I don't know what means for feed back plan or section. what means for feedback?
Thanks.
11 Replies 11
LiHigh
I found out that glob_context=22 only works for drawing elements but not TEXT2. What is GS thinking?
Luckily, there is a Workaround--script 3D text and use PROJECT2!
Howard Phua
Win 10, Archicad 19 INT
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
Guys from GS, could you give us at least rough explanation of what is going on with those numbers?
We added a chapter to our Technical Standards documantation on: http://download.graphisoft.com/ftp/techsupport/documentation/developer_docs/BasicLibraryDoc/ explaining the codes.
Go to Technical Standards / Ch.3.7 "GDL Execution Contexts"
Gergely Kmethy
