mukster
W Sliding3 21 Window
Using Archicad 21 on a Mac platform. Putting in a 3 panel sliding window with a center picture. I can find no way to adjust the width of the panels. We need to make the center panel larger than the 2 side panels.
3 Replies 3
Do you have the '3-Sash Sliding Window 21'?
This is available in the AUS library - not sure about other languages.
If so you can set the panel configuration to custom.
Lingwisyer
Guru
Which edition of AC are you using? If I recall correctly, the US edition uses different windows than that shown in Barry's post as he pointed out. I think the INT edition has the same windows and AUS so you might be able to use that if need be.
Ling.
mukster
Using AC23 now in the US. This option is not available on my version. I'll have to look this up
