W1 casement 13 pivot lines in elevations and 3d
Can some1 help me, ive been looking for 25 minutes where i can turn off pivot lines on W1 casemant 13 window and i cant find it Can some help ? Am i blind ?
thx
24 REPLIES 24
In the dialog of Model View Options.
cheers,
cheers,
thx man !
What?
I have not loaded 13 yet.
Have they really put it under mvo global settings?
What happened to a window's parameter settings.
Parameters>3d Rep>Opening lines in 3d?
Which worked per individual window fine in 12 I thought.
A new trick?
ztaskai
Graphisoft Alumni
Graphisoft Alumni
A new trick?
Yes, a new trick:) All options which typically are depending on the given views are now set in the model view options dialog. This is an open technology, so 3rd party library developers can use it too. (Window parameter settings is still there, naturally.)
Regards,
Zsolt Táskai
ArchiCAD Development - GDL Team
AC13, AC14 and upwards...
Erika Epstein
Zsolt,
I know it has been brought up before, but is it possible to add back in the ability to over-ride these global settings on individual basis?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
ztaskai
Graphisoft Alumni
Graphisoft Alumni
It is possible, sure. The problem is that two controls for the same function necessarily create a collision which has to be resolved. We circumvented this situation by dropping the individual setting for most view dependent settings (not all of them but won't look it up right now). Naturally, we expected feedback from the users after the release of AC13.
For which view options would you need individual setting?
Regs,
Zsolt Táskai
Zsolt,
we have solved this problem, that all the parameters that are in the MVO have the same UI in the win-door objects. In the object UI you can turn it on/off the "use the MVO settings" parameter.
I think one of people want to use individually the pivot lines and the others the type of the opening lines, ect...
Regards,
Erika Epstein
Regs,
Since you ask
It's great having the abilitiy to make global settings like turning off knobs taps and handles for 3D work, but there are times when doing any phase where you may want them.
1. show door knobs on doors you walk through, but not cabinet doors.
2. Sometimes we show a fixed version of a door such as a patio door assembly and we want only the operable ones to show the swing. Or to show active leaf of a pair of doors.
3. Door & window opening line: some use this to differentiate doors. This has been discussed elsewhere .here for one discussion.
4. Show additional hotspots for d/w and the Minimal Space only as global on/off have as yet not been a problem for me.
HTH
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Rod Jurich
ztaskai wrote:
It is possible, sure./........
Szia Zsolt, we do a lot of renovation and addition projects.
To be able to show existing clearly from new is the big plus our local
GDL guru has made available in his latest 4D Library
We can globally set many MV options and then decide which parts
be they doors/windows/cabinet/fixtures to display differently.
I am sure it could make it in v14
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
