WINDOWS AND DOORS PROBLEMS
Hi
I'm having a problem that's drive me crazy.
I'm working in a project for several weeks, since yesterday each time that i open the project i lost all de windows and doors setting (and they are a bit hard to set up).
Does anyone knows how to solve this problem without changing the settings again and again?
I'm Installing now the latest hotfix, i'm afraid that its a build related problem, since i'm using the latest library with the build 970.
2 Replies 2
Djordje
rasaos wrote:
Hi
First, why 970??? It is VERY old! Current one is 1200 - assuming that you are on the International version.
Update your Archicad and then let's see ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Do your windows show up in 3D? You may have to correctly set your Cut Line.
