Wall Lamp RCP Symbol
Im using Wall Lamp 05 15, on archicad vs. 15 US.
The lamps RCP symbol is offset from the actual model. So if I move the symbol in the RCP to be adjacent to a wall, the 3d Model appears inside the wall. And if i move the 3d model, so the lamp is back on the wall, the RCP symbol is now floating in the room.
Is there way to "add" an offset setting so the RCP symbol to get it where it should be? Or another object that works better.
Alternatively I've been having to have a 2d symbol object, and a 3d object. So two things need to be updated instead of one.
0 Replies 0
