Wall claddings changing stories
Using Cadimage Wall Coverings - when I make small modifications to wall coverings they often jump to another story.
eg: Say a wall covering has Storey 1 as it's home storey. If I do something such as change the setout or even the colour of the cladding it then jumps up a storey. When I check the home storey in object settings it is now Storey 2.
I then cannot get them back onto Storey 1.
I don't recall this happening with earlier versions.
I don't know why it is doing this as I don't use the Cadimage accessories.
But if you select it then EDIT > ELEMENT SETTINGS > RELINK HOME STOREY does that help?
It may be a bug in the Cladding Tool in AC18. Have you tried contacting CadImage yet with your problem? They are very responsive in my experience.
Gerald Hoffman
ā€œThe simplification of anything is always sensationalā€ GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
Thanks guys, Cadimage are fixing it.
Relink Home Storey does not work.
It doesn't seem to occur when editing in Floor Plan; only in Elevations and 3D.
