sarahric
Wall to wall junctions
I have some walls to the side and above another wall but on the same plane (ie in a straight line). They are all using the same composite wall type and same finishes, but can be on different layers or the same layer.
My problem is that in 3d I can see the join of the 2 walls. How can I remove this join?
ArchiCAD 18/Windows 7/16GB Memory/i5 3.2GHz Processor/NVIDIA GeForce GT 610
10 Replies 10
Ahh, so one must have had a different setting to the other - layer or surface material.
Glad you got it sorted.
