2010-11-08 04:00 PM
2010-11-08 11:51 PM
Revenant wrote:You can rotate objects with OBJECTiVE. It also adds the required rotation parameters to objects that lack them. Referring to the attache image:
How do you guys go about changing the angle of things that don't have the option in their parameters?
2010-11-09 12:50 AM
You can rotate objects with OBJECTiVE.Thanks for you help Ralph!
2010-11-09 08:12 AM
Revenant wrote:As a student, you can use the software free of charge. It automatically recognises student licenses.
I found out you can trial the program
I can't believe that you cannot move an object in such a simple way in archicad itself though. So the only ways you can rotate some objects are using 3rd party programs?
2010-11-17 07:26 AM
Ralph wrote:Thanks you so much! It works perfectly!!!Revenant wrote:As a student, you can use the software free of charge. It automatically recognises student licenses.
You can also give objects the ability to rotate by changing the program that defines it, but even then you can't rotate many objects about a common axis. The purpose of OBJECTiVE is to enable you to do these things with the same simplicity as the rest of ArchiCAD.
