Where are the cabinets?
OK I'll bite. New to Archicad.
Where are the cabinets so I can draw my Kitchen?
Did a search, nothing. Looked in CSI libraries, nothing.
taoist
4 REPLIES 4
Object tool (chair icon). Become familiar with the "Find' function as shown in the attached as you get used to where things are located in the libraries.
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Taoist,
You should add the version of Archicad that you are working on into your signature as the answer to questions can be different. In version 14, Cabinets are located in the Furnishings directory. See attached.
Gerald Hoffman
ā€œThe simplification of anything is always sensationalā€ GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
Thanks, Karl and Gerald.
Can't wait till get home to explore all this.
Stress Co_
Check also the Depository for an object called "CabinetONE"
http://archicad-talk.graphisoft.com/object_depository.php?
Depository> 12 Furnishings >Cabinets Shelves
Marc Corney, Architect
Red Canoe Architecture, P. A.
