Who ate the Archicad Model Library
PH Architecture
The library that came with 28 is missing all of the standard US components. It appears to be just furniture.  Supposedly there is a method to return to the US library but there is no information as to how to load this library.  Is anyone else having this issue or is no one using 28?
Operating system used: Mac Intel-based
11 REPLIES 11
Hi Eduardo,
It looks like you have the object library from AC27 loaded. In the global library .libpacks for AC28 I'm not able to find an equivalent.
AC26 5004 | MacBook Pro (16-inch, 2023) | Sonoma 14.0 | Apple M2 Max | 32 GB RAM
That is correct. The libpack one doesn't have them though the regular Monolithic one does.
Misread it.
You can extract them from the Monolithic library as I had to do with the Medicine Cabinet.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Setup info provided by author
