‎2017-08-08 02:22 PM
‎2017-08-08 05:36 PM
‎2017-08-09 03:31 AM
‎2017-08-09 01:18 PM
Barry wrote:The calculation that defines the points in the object as in rail_width/2-(rail_width/2-0.49*********)
Otherwise I don't understand what you mean by 'calculation' as all you have here is a polygon definition.
‎2017-08-09 03:49 PM
‎2017-08-10 03:18 AM
‎2017-08-10 04:00 AM
Bruce wrote:If there is a 2D script this should override anything drawn in the 2D symbol window.
Have you checked to make sure you haven't accidentally created a 2D symbol, as from memory this will stop the 2D script from running?
‎2017-08-10 04:03 AM
JGoode wrote:I don't see anything wrong with your script.Barry wrote:The calculation that defines the points in the object as in rail_width/2-(rail_width/2-0.49*********)
All bits of the definition that included this didn't work so I was wondering if there was a reason why they wouldn't work. I have it working now anyway using a different method.
‎2017-08-11 06:54 AM
