Guru
Window / Door Editable Hotspots
Hi all,
I have a set of 3D Angle Hotspots but in Plan View the Moving Hotspot becomes inactive for some reason.
To remedy this I thought of overlapping a set of 2D Angle Hotspots but realised that since the object is a window, there is no way to assign the z-axis meaning that this command set does not work for doors and windows? As far as I know, hotspots are not affected by transformation commands so I cannot just flip the y-axis with the z-axis.
Ling.
Win11 | i9 10850K | 64GB | RX6600 Win11 | 5900X | 32GB | GTX2080TI
1 Solution
Guru
Have not managed to get the 3D hotspots to be usable in 2D, so I have hidden them in plan using the Glob_View_Type command. My problem with the 2D hotspots was a lapse in thinking, as I was putting them in the 3D script... woops...
Ling.
Go to post
2 Replies 2
All works. see the standard windows with the 2d opening parameter.
Remember the coords work differently in openings.
Piotr
Guru
Ling.
