2006-07-09 09:00 PM - last edited on 2023-05-26 11:39 AM by Rubia Torres
2006-07-09 09:07 PM
2006-07-09 11:53 PM
2006-07-10 03:20 AM
2006-07-10 04:51 AM
g.h.design wrote:have you tried the 'Cut Line Pen' under the 'Floor Plan and Section' panel of the settings dialogue?
It is linked to pen #1 but I can find no settting to control it. I have looked through every window / door setting I can think of. And even some that I can't...
2006-07-10 07:50 AM
2006-07-10 08:05 AM
have you tried the 'Cut Line Pen' under the 'Floor Plan and Section' panel of the settings dialogue?Yeah, tried that. It's the Object's Pen setting. I think it is a bug. Can you replicate the problem? It pops up even if I start a new file using all Archicad defaults...
~/archiben
2006-07-10 08:20 AM
I have located where the problem is. It is the symbol line pen. If I turn off "Enable Object's Pens" all the line weights unify and the heavy line goes away. I can't find a single, seperate setting for that line alone...I don't think that's the problem unfortunately. What you are looking for is the contour functionality that we had in our AC9 Library windows. It seems that the functionality disappeared with the SE9 Library.
2006-07-10 03:49 PM
g.h.design wrote:I can't get it to happen on any of the AC10 windows I have tried. Has anyone else reproduced this?
It occurs on all AC10 library doors and windows.
2006-07-10 04:57 PM
