Window Marker and Door Marker
How is it possible to save a windows marker? the ability to load a window marker is quite evident though i have had no luck following the little info there is on how to do this, i know the work arounds such as select all windows and doors and adjusting marker settings accordingly though i want to make my marker permanently there from the drop down.
I have searched and only info i have found is from 2011, please help.
Currently using Archicad 19 (Edu) on Mac OS 10.11.4
11 Replies 11
I don't know the reason for this behavior, so I have reported it to GRAPHISOFT as a bug.
Minh Nguyen
Dave wrote:
Lazlo,
I've saved the marker and it's always available to choose. The problem is that the marker size is never correct (always 73.7 instead of 26 pt) nor is the pen used (always 1 instead of 3). Every other custom setting is correct--font, font size and width, marker shape, positions, offsets, etc. Even overrides. See images.
Hi Dave,
Thank you for your question and I am sorry about the issue!
May I ask for a test PLA file from you, in which I can find the problematic custom marker for a closer look and comparing with my version? Let me know if you'll need a secure link to send the file to me. Thank you very much for your help!
Looking forward to hearing from you soon!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
