2018-03-06
01:06 PM
- last edited on
2023-05-24
12:27 PM
by
Rubia Torres
2018-03-06 02:04 PM
2018-03-07 08:29 AM
Erwin wrote:By saying "complex profile", do you mean the Composite of the wall? If so, there is no composite. The wall is created with the geometry method: polygonal. I then added the arcs using shells. I did so because I had a window inside a niche inside a niche (reminds me of Inception). I tried to create such a window with multiple niches and put it in a wall with geometry method:straight, but I could not get the plan to show as I wanted.
In your complex profile look where the opening reference lines are.
If these are allright, you've set up some huge reveal depth.
2018-03-28 03:14 PM
