Well, it looks as though, after more digging I'm going to answer my own post again(believe me, I'm not doing this on purpose, I just hate to give up and wait for an answer
. I found that the AC_WIDO_TYPE parameter had been set to array in the LHS marker.(I assume this caused the array warning ) This set it's value to [1], with the brackets. I looked at a few other markers and found that they weren't set to array and had a value of 0. I made the changes to the LHS marker and Voila! If I placed a new door then it showed the text...a new window did not. I'll tell you what...If you've run out of challenges in life (and you're not a gdl guru already), then Dive In!! (I would suggest making a backup copy of your libraries first though)
I'll be back!
Doug
